pistons decked and hone LS1
Old 04-19-2013 | 07:32 PM
silverado2000's Avatar
Default pistons decked and hone LS1
I have a 2002 LS1 I just got back from the machine shop. This is what the machine shop did to it.
vat
Decked the block .008
Honed the block .0025-.003 (Finished size 3.9005-3.901)
Im trying to figure out if my deck height is off now, am i going to have to mill the top of the pistons? Also is std. bore pistons what i need?
If anyone has the email to someone that will help me out with this id appreciated it. I cant seem to find anyones email at texas speed, thats where i plan on ordering most of my parts from.
Old 04-19-2013 | 07:52 PM
gao8302's Avatar
From the looks you should be just fine. Get a little bit thicker head gasket and some file fit rings.
Old 04-20-2013 | 12:33 AM
how bad is piston slap gonna be if i put standard bore ls1 pistons in this block?
Old 04-20-2013 | 03:55 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Standard LS1 bore 3.898.
You would have to measure the actual pistons you plan to use to see how far off they are from the new bore size. My best guess would be more then .003 would slap pretty good especially on cold start up.
As far as the deck goes you need to assemble the engine and measure how far out of the hole it is. That is the only way to know for sure. If your more then .010 out of the hole, you need a special thicker head gasket.
Old 04-20-2013 | 04:52 PM
Thats my problem, i cant seem to find a good set of pistons for the new bore size.
Old 04-20-2013 | 10:14 PM
bluebommer07's Avatar
are u planning on stroking it with that bore?
Old 04-20-2013 | 10:20 PM
1FastBrick's Avatar
Will you be running forged pistons???
Old 04-20-2013 | 11:58 PM
The plan is scat rods, arp bolts everywhere, forged pistons, stock crank, 317 heads.
lukn4trbl355
10-22-2015 12:19 AM
turbo6c3
10-05-2015 07:11 PM
trevorh1
09-27-2015 09:47 PM
sTNT971
09-26-2015 05:22 PM
