Pistons: Forged or not
Old 08-17-2011, 02:58 PM
11 Second Truck Club
Sn0wBa11's Avatar
Default Pistons: Forged or not
I'm building an iron block ls1 using a stock ls1 rotating assembly and a 5.3 block bored to accept standard size ls1 pistons. It's getting a set of 243s decked .015 and probably a good EPS cam.I will occasionally be spraying a 150hp shot of nitrous through it but not very often because my truck is only a street machine. It only see's the track once maybe twice a year. So here's my delima, I'm trying to decide if I should do the forged Mahle pistons which are gonna set me back about $650 or just go with some stock ls1 pistons which can be had for virtually nothing. I know the forged pistons are gonna handle the abuse from the n2o alot better but then again there's plenty of you guys runnin around with 200hp shot on stock pistons. With that being said, any thoughts or suggestions? Keep budget in mind also..
Old 08-17-2011, 03:49 PM
TXsilverado's Avatar
both will work, but if i was in that far and had to buy pistons, i would go forged.
Old 08-18-2011, 03:46 PM
slowswb's Avatar
forged rods and pistons i would go that route if you got that money. diamond piston have a nice set nitrous pistons.
Old 08-18-2011, 07:06 PM
06Sierra2's Avatar
Forged since u have it apart. It would suck to go the cheap route and not have piece of mind or worse something messes up
Old 08-18-2011, 07:18 PM
Sn0wBa11's Avatar
True, guess forged it is!
Old 08-19-2011, 09:06 AM
joeyc125's Avatar
I'm running autotec 4032 forged pistons, they are very reasonably priced, outstanding quality. Pm me if you are interested. Btw, I think you would be a little more comfortable knowing you have a little more cushion rather than pushing the stock stuff wondering how far is too far.
Old 08-19-2011, 09:18 AM
on a budget i wouldnt even worry about the rods. i see pistons coming apart 10x more than rods. i would just do forged pistons and arp rod bolts and call it a day.
Old 08-19-2011, 11:09 PM
Sn0wBa11's Avatar
Yeah I'm am doing arp rod bolts for sure. Joey in sending a pm your way
Old 08-20-2011, 03:43 PM
Resident Retard
BlackGMC's Avatar
Screw all of that. Go buy a pull out LQ9. I have not seen 1 built motor last more than a few thousand miles on this board. Buy some good heads and a low mileage LQ9 and be done with it.
Old 08-20-2011, 11:07 PM
Sn0wBa11's Avatar
Screw a lq9, a 6.0 around these parts is hard to come by and high as giraffe pu$$y. If a built motor isn't lasting more than a few thousand miles then someone needs to quit bulding them IMO. I can build this motor for for just a hair over a grand.
Quick Reply: Pistons: Forged or not
