Is polishing my heads worth anything?
When I do the cam swap and my heads are off for the spring swap, should I go ahead and do a light polish on the heads?
The cam is a vinci ultra tq cam, motor is built for towing so porting them will hurt my low end tq slightly, but what about a light smoothing polish?
5.3L ext cab 2wd 3.42 all external bolt ons done
Also, gears have been my best mod yet
Truck has 150,000 miles so I am replacing the lifters and trays. I don't know how to do it with out taking the heads off
210/218 .551/.551 on 116lsa
I already have 1.8 yella terra rockers installed. so lift with the cam should be around .583/.583 lift
I 100% agree on the 3.73 and 4.10 for towing, but not fuel millage when not towing. I get around 23mpg at 75mph with the 3.42 get about 16-17 pulling 4500lbs boat
DO NOT polish your intake runners, there needs to be someting in there to create turbulance to help the fuel stay suspended and atomized before the chamber. If you do polish it then your mpg's and throttle responce will go way down. You can remove the casting flash and that will help. Its quick and simple to do. Just dont get too carried away with it.
Iv never seen a smooth polished intake port. Iv messed with all types of heads and the best porters in the industry ( not particularly talking about gm ls heads) leave the intake with a rough grit sandpaper finish or the cnc " rippled" effect. Its kinda like the golf ball affect. You don't want air to stick to the head so to speak. Itll flow over it nice and quickly... But the combustion chambers and exhaust ports I have seen have been polished very slick.
