port/polish/milled 862 heads, Worth the $$$
LS6 have 3.905 bore, but the valve spacing is the same as a 5.3 head. The larger valve diameter (2.00") combined with the smaller 3.78" bore is what causes the shrouding effect. Same thing would happen when you put a 2.00" valve in a 5.3 head. Milling a head also can negativly affect flow slightly by placing the valve closer to the cylinder.
yeah but dont the L33 5.3 have flat top pistons so the head wasnt milled to up compression they just went with a flat/domed piston instead? That would be why there is no direct hit on the flow because the valve distance hasnt moved like Tdrumm is getting at.
Are you sure that they are 243s? Patriot used to market a "LS6 style" head that was a 317 head that they had weled up the chamber to get the volume down. Also, 2.00" is the max intake valve I'd run on a 5.3, and I'd be willing to bet that those heads have 2.02s and use larger port volumes to get their flow numbers, which could affect low speed torque.
