prc 2.5 vs trick flow 225
i got a lq9 ,cam,fast 92mm.full bolt ons with prc heads milled 59cc on stock gaskets,11,1 compressionm so i wanna make power so im looking around at better heads . trick flows 225 and going to 11.5.1 compression im looking for 20=30 rwhp and equal torque any help would help
FormerVendor
Not really a fair fight between a ported GM casting and the TFS 225's, IMO....the PRC 5.3's do tow the line very well and make great power for a great price though! But if you really want a fair comparison, the PRC 227's should be rolled into the equation against the TFS heads
http://www.texas-speed.com/shop/item...=1068&catid=40
i knopw prc r great and the price is also good but im looking for whatever is next on the list as for a beter head.ive heard from other websites that a fully ported ls6 head is the up grade head but dont know. also is 11.5 comp. a 91 friendly comp?any tried it?
If you have 59cc heads with a stock 0.051 gasket right now your compression is 11.7:1. You should be running 93 octane. This is assuming the pistons have a zero deck height which probably isn't the case. They probably stick .010 out of the hole so you compression is actually closer to 12.0:1.
