ptv clearance
ptv clearance
ok so i am wondering what the stock heads ptv clearance is with a cam that has .610 lift. I am running prc stg 2.5 heads and .610 lift and am curious as to how close i am. motor is a 5.3l stock bottom end, stock pistons.
thanks
thanks
grr kinda what i was thinking after reading a bunch of kinda close to my setup threads.
so how close is close with this setup. and yes i know i should have checked but i just put in new rockers with larger ratio so the ptv would have changed anyways.
maybe someone out there is running something similar can chime in.
aklowrider, did you check your ptv clearance, your cam has a little less left than mine and are running the same rockers.
Thx
Thx
No, I didn't. My heads have not been milled, and I'm using a relatively low (.551) lift cam. After the 1.8 rockers, my valve lift is at .583, Roger Vinci advised me not to worry until around .600 lift to start checking, unless heads have been milled. That also seemed to be the general consensus when I did my own researching on the boards. Also, since I'm using a Maggie, my duration is not too wild.
You can have all the lift you want, if the piston is down low it wont matter. Duration has more of an effect on PTV than lift. It's advisable to physically check PTV with all cam swaps regardless
thats what i was gonna say. i would bet that cam would clear with the low duration.
I have no issues with my setup... My heads are milled .30 and i run a .040 head gasket, and my lift is .600+... Luckily Ed Curtis designed my cam with all of that in mind, so i figure he knows what he is doing...
zblee
11-11-2015 01:41 AM
lxcoupe
10-26-2015 11:13 AM
lukn4trbl355
10-22-2015 12:19 AM
LSX-81-SIERRA
09-05-2015 03:51 PM
