PTV issue? L92 and LQ4
What is it and will I have it? I have a stock LQ4 motor with L92 heads unmilled with .600 lift and a 228/236 115 cam and I would like to know what issues may arrive from this and if it works what horsepower numbers rwhp through an automatic and flywheel.
http://www.impalassforum.com/vBullet...=191204&page=2
Thus was my setup: Essentially it was a LQ9
LS2 Pistons and Rods
10.9:1 Compression
L76 Intake
L92 Heads UnMilled
LS2 90mm TB
228/232 .595 112 Comp
4.10 Gears
Pacesetter LT w/ORY
Stock Stall
Stock 4L60
Stock muffler
Crappy plugs
Dyno put down 368/355
https://www.performancetrucks.net/fo...d.php?t=394008
10.9:1 Compression
L76 Intake
L92 Heads UnMilled
LS2 90mm TB
4.10 Gears
Pacesetter LT w/ORY
Stock Stall
Stock 4L60
Stock muffler
Crappy plugs
10.9:1 Compression
L76 Intake
L92 Heads UnMilled
LS2 90mm TB
4.10 Gears
Pacesetter LT w/ORY
Stock Stall
Stock 4L60
Stock muffler
Crappy plugs
10.9:1 Compression
L76 Intake
L92 Heads UnMilled
LS2 90mm TB
4.10 Gears
Pacesetter LT w/ORY
Stock Stall
Stock 4L60
Stock muffler
Crappy plugs
i am building an lq4/l92 combo, and i too was hoping for 400+ at the wheels. im just gonna build the motor and see what happens. im gonna run the l76 car intake and long tubes.
Between this:
Stock Stall
Stock muffler
Crappy plugs
and the wrong cam for that kind of setup, I was suprised I got 368. With the right exhaust and cam selection I think I would be easily in the lower 400 range.
Stock Stall
Stock muffler
Crappy plugs
