Pulling off harmonic ballancer putting on Asp
When I get off of work I'm going to put on my Asp underdeive pulley, do I need a special tool to get that off? It might be a dumb question but I just wanted a heads up b4 I get home
Baltimore Whore
Yes you need a puller, also a new longer pulley bolt to get the new one started on.. You can rent one at a parts store... Just a tip, before you try to put the new pulley on, let it soak in a pot of hot hot water so it heats it up to expand big enough to start on the crank, then you gota roll so it doesn't cool... You should also get a new crank bolt...
AHelm3
04-08-2016 08:51 AM
05GMC4.8
08-07-2015 10:55 PM
