pushrod length????
pushrod length????
i have a 2007 4.8l rcsb
i would like to get a cam with the specs: 216/220 112LSA +4 .561/.564. also i want a thinner head gasket of .42 rather than the stock .52. what size push rods would i need? or is this something im going to have to check when i have it assembled in the truck.
Sexy Party Mod
Gotcha. Here is the pushrod length calculator on tech. http://ourworld.cs.com/ls1info2/Pushrod+calculator.xls It seems to be fairly accurate. Ive used it a few times Make sure you know the base circle of the cam. Hope this helps.
Originally Posted by 4.8T
any body know how far the pistons stick out of the hole on the 4.8l's i need to know so i know what heads gasket we can use on his eng. .42 should work great but can we close the quench even more?
11 Second Club
jtphelps289
09-29-2015 12:00 PM
