Pushrod length?
Pushrod length?
I'm installing a mild voodoo cam in my freshly rebuilt 5.3 is it really necsasary to check the pushrod height? I haven't changed anything but the cam. I do want new pushrods which ones are yall running? I'm thinking lunati or tsp. Thanks for your input and replies!
14 Second Truck Club
i did just change from 7.350's to 7.375's thinking I needed the longer ones... cant tell a bit of difference... still runs like poo at low speeds..... waitin on valve springs and then takin the asa cam outta the ecsb
FormerVendor
Exactly! We've installed basic 224R camshafts that if you made a thread about what length many would swear it should be 7.400" (stock long-block, just a cam swap), and they required as short as 7.350" to setup the preload properly! It is a $20 well spent for the tool to check this!
It's not very friendly to use since the base sits below the heads surface, so you have to do trial and error in/out.
Are you guys using the adjustable pushrod set to a specific value and then using machinist blue dye to characterize the rocker arm wipe pattern on the stem?
And if so...how do you avoid the large smear of a stock rocker arm?
I'm sure it can be done...but what's the trick?
I'm trying to figure mine out. All the methods online are getting confusing, I wish there was a tried and true method.
FormerVendor
Matt - I bought the Pushrod checker from Comp.
Are you asking how to check your swipe pattern to see if you need to shim the pedestals??
