pushrods? roller rockers?
i have a 5.3L s/ced w/ 02 z06 cam, ls6 springs, longtubes and exhaust. should i get different pushrods? also, which ratio roller rockers should i get... 1.7 or 1.8? thanks.
Do you have $650? If so, get the 1.85 Comp Pro Mags and some hardened pushrods. If you have a little more cash go to the Jesel SS shaft mounts, but I don't think they come in the 1.85 ratio.
I AM A MOTHERF*CKER
I'd get the 1.7 ratio rollers since you already have the cam -- let it provide your lift and duration. If you do go for the bigger ratio, make sure you re-figure the lift and clearence with the new ratio to avoid piston-valve procreation (their offspring tend to be heartache, sorrow, and empty wallets), and respec your springs.
AFA pushrods, if you need them for length get 'em. Heck, even if you don't, I think hardened pushrods are like 90 bucks...
what a rush!
Originally Posted by Dark Halo
so is there an advantage to using stock sized roller rockers?
Less friction, better valve control using quality pieces.
KINGCYCLES
10-02-2015 10:21 AM
