rate my setup
rate my setup
Ok, so after my recent thread about some shavings in my oil, i thought it might be a good time to do a whole top end rebuild. My plans are as follows:
prc 2.5 5.3 heads
cometic .040 gaskets
arp head bolts
new oil pump....melling or ported ls6?
new rockers, looking at harland sharp non adjustable rollers
timing set- ls2 chain only or the whole timing set?
ls7 lifters, ls2 trays (already recieved them)
Budget is a concern, so if you see anything not really needed then let me know. I currently have 82xxx on the truck and mileage will continue as it is my dd and have a 3,000 mile roadtrip planned.
prc 2.5 5.3 heads
arp head bolts
prc 2.5 5.3 heads
arp head bolts
prc 2.5 5.3 heads
arp head bolts
if you found shaving in the oil pan id be more concerned about the rotating assembly than wanting to ugrade the topend!
What injectors are you running?
I wouldn't worry about the rocker arms. Or the trunion upgrade.
Not real sure if the timing chain is a necessity either. I'm running the one that came on the 6.0 that was swapped in. It had slack in it. But they all do. The 4.8 with 160k that came out was put in someone elses truck and is still running w/ the stock timing chain.
Same story on the oil pump. Unless you have oil pressure issues, I'd run the oil pump you have also. Its a gear pump. They don't wear out that easy. Still running the stocker in my 6.0. The one in the 4.8 w/ all the miles put up good psi before we took the engine out of the truck.
Skeet raised a good point about the shavings. You're 100% on where they came from?
Stupid I know but I think the drip pan might have been dirty to begin with. When I wrenched off the k&n some paint and metal flaked off in the pan. I changed the oil again just to check it out and the plug had just a spec of metal. Wouldn't even call or a shaving really
