Re-use ARP Head Bolts?
My point wasnt that they arent strong enough just that they are hard to remove without screwing up the heads of the bolts.
James
Tin Foil Hat Wearin' Fool
Originally Posted by onebadrubi
How are they any harder then anyother bolt to NOT screw up the threads when removing? They are even harder material I would think they would be even stronger?
With head studs you are only having to spin a nut where as iwth a bolt you have to spin the whole thing and there is ALOT more friction. It has NOTHING to do with the threads, it has to do with the head of the bolt. When you are hunched over in the engine bay trying to get the bolts out sometimes its hard to get straight on to the head of the bolt and with them being 6 point it makes it even harder not to round one off. 12 point heads are much more forgiving.
Dude do you just follow me around trying to prove me wrong with your "I think" BS or what? Once you start spinning some wrenches and get some experience under your belt then start trying to prove me wrong OK.
WELL HERE GOES!!!!
Who are you to insinuate following ANYONE or maybe hinting to many post? YOu have a comment in EVERY POST.
I was in no way "dissing" you, your work, your truck, or knowledge. I was simply asking how a hardened bolt/fastener gets "fed" up from removale. I know understand by messing up the heads, that all you had to say man. Not hey I want to be dick.
HAHA and to ruin your fun, I have a big belt with a little more knowledge under it then you think. But that is irrelevant and im not gonna break down my knowledge of turning a wrench.
Im not turning this into a bash like the last time 1slowz71. This is all I will say on the subject. My question was more then answered!
you wont need it I got my point across and am not going to continue the convo anymore. The OP's question was answered more then enough.
