Rebuild 6.0L help
Old 02-02-2009, 09:54 AM
  #71
clemsondave's Avatar
Originally Posted by SynergyV8
When you're hard pressed to get the job complete, the GM dealership can be your best friend for parts. It's just too bad the convenience of having those parts in stock means extra cost.
Yea, I have gotten a few things from them. Most have been 20-30% more. This part was $58 online and $161 at the dealer. I just need to get this done.
Old 02-02-2009, 08:49 PM
  #72
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by clemsondave
Considering what the dealer wants for it, I might just fly out there!
Thats to Bad... Thats why the have been nicknamed "The Stealership" of course we have all been in that pinch before so I guess thats the way the dice roll...
Old 02-02-2009, 09:20 PM
  #73
vrmmm vrmmmm! Took us 3.5 hours and she started right up!!! Pretty good time if you ask me. Much quicker than pulling it out. Of course, we didnt have fluids leaking everywhere this time.
I've got a small coolant leak and I need to figure out what that part is called. There are 4 of these little blocks. They bolt to the top of the heads near the valley. The front ones have a cross over tube connecting them. One of the rear ones must have a worn gasket.
Here is a picture. Parts in question are circled.
Old 02-02-2009, 09:46 PM
  #74
1FastBrick's Avatar
front one is a coolant cross over the rear ones are block offs. There is a special washer with a ruber o-ring built in. Part Number from Gm is comming up I have to go dig them out of the garage... Be back in 5...
Old 02-02-2009, 10:47 PM
  #75
1FastBrick's Avatar
Damn I forgot were I put them.... I finally found them though...
The Gm Part number for that seal is 12551933
There is 4 total they are the same front to rear. They go between the head and the little Block off plugs you circled, also under the front cooling cross over. I am sure you know, Just make sure they are clamping down evenly when you tighten them up. Never hurts to use a little Silicone either...
Old 02-03-2009, 08:08 AM
  #76
Thanks
Old 02-03-2009, 10:30 AM
  #77
1FastBrick's Avatar
I was curious if you mistakenly put one seal back wards??? Either way should probally get replaced...
So did you make that engine Stand??? Never seen one that has it's old handle holder... also the head unit looks alot tighter then most.
Old 02-03-2009, 10:45 AM
  #78
SynergyV8's Avatar
All of mine have a handle holder, just like all my engine hoists.
http://www.northerntool.com/webapp/w...3359_200313359
clemsondave, are you having your tune done by the same people who did your Vette?
Old 02-03-2009, 10:53 AM
  #79
1FastBrick's Avatar
Damn...Learn something new and find a new product every day!!! Thanks! It Looks just like his... I am tiered of fighting with my cheapy stands. Other problem is I am Tall so I have to bend over to work on them. Really kills the back.
Old 02-03-2009, 11:02 AM
  #80
SynergyV8's Avatar
I'm 6'2"-6'3" depending on how thick my socks are that day. I know what you mean by bending over for the "common man" engine stand that assumes we're all 5'9". To remedy this, I had my son fetch square tube stock slightly larger than the tube stock used to build the upright on the engine stand. He cut the upright off at the base and welded the larger piece to the base of the engine stand in the same manner the upright was. He cut the larger square stock about a foot from the top and slid the original upright into the larger square stock much like a boom you would see on a crane. A few dowel pins through both pieces with stepped holes every few inches and now you have an adjustable height engine stand.
My son has my wife's DNA so when he's working on a project he slides the unit all the way down to suit his 5'7" stature and when I'm in the mood for a little wrenching it gets moved all the way up. The only problem with this setup is that once there's weight on the stand, it's impossible to safely remove the dowel pins to change the height so one has to plan ahead. Usually our engine rebuilds are complete after the weekend so it's not a big deal.
Quick Reply: Rebuild 6.0L help
