Rebuilding my junk yard 5.3 pre 2002 I think, some help would be appreciated
So I have this engine tore down to the short block and I wanted to up the horsepower a little when I put her back together.
From all I have been able to gather I can put 4.8 flat top pistons on my 5.3 rotating assembly. This is where things get weird. I've talked to several vendors jegs, summit, ebay sellers trying to get verification that this is a safe modification. None of them can give me a yes or no answer.
So I'm wondering if I bought a 4.8 engine rebuild kit from summit or jegs it should work as the only difference between 4.8 and 5.3 is the rod and stroke correct?
Has anyone actually done this or am I stuck with stock dished pistons unless I'm willing to drop 800 bucks on some forged slugs, which I'm not willing to do.
Thanks ahead of time.
I have a gen iii engine, I was under the impression you can't mix rods, as far as I'm aware the l33 has a different rod. Am I misinformed? Even then I don't know where I'm going to find an l33 in a junkyard
Custm2500's Rude Friend
An L33 is a factory built 5.3L engine with Flat top 4.8 pistons.
The Vendors only know what the manufactures tell them.
There is no difference in Pin height between the 2 pistons. The difference is in the rod and crank stroke length.
If you're using 706 or 862 heads, your compression ratio will be around 10.5:1 this way.
SlvrSierra4.8
02-24-2016 09:18 AM
crashmymax
02-09-2016 04:01 PM
NateBower002
01-17-2016 06:29 PM
