ridiculous ticking
Old 01-20-2010, 04:06 PM
  #21
WorkTruc's Avatar
Originally Posted by viciousknid
What pushrods are you using Worktruc?
Anassix. Do you have DOD and did you change your lifters? I just realized you are an 08 and if you have DOD I recall that you have to change the lifters.
7.4 comp pushrods
Old 01-20-2010, 06:10 PM
  #22
Where's the Beef?
viciousknid's Avatar
Originally Posted by WorkTruc
7.4 comp pushrods
Thought so. That was my mistake. Been a while since I bought some. I THINK it's going to be the lifters if you are DOD and didn't change them. but would have to search those threads and don't have time.
Old 01-20-2010, 07:27 PM
  #23
Mod with training wheels
smokeshow's Avatar
Yes I changed the lifters... They are all LS7 lifters now. Valley cover was swapped, disabled DOD in the tune...the works. Now it sounds like a sewing machine.
Old 01-20-2010, 07:39 PM
  #24
Where's the Beef?
What springs did you use? Can you get a video of how loud it is?
Old 01-20-2010, 08:17 PM
  #25
smokeshow's Avatar
I used the LS6 yellows. I could try to get a video with my digital camera but I can't say how good the sound quality will be.
Old 01-21-2010, 12:13 AM
  #26
Where's the Beef?
Incase you didn't see i would hold off on 7.425 That was a mistake on my part.
Where are you from Maybe someone can assist locally/
Old 01-21-2010, 01:18 AM
  #27
zittman's Avatar
I called Comp Cams and Texas Speed again and talked to them about the noise. They said that the camshaft is a aggressive design and it would make the valve train noisy. I guess I am not 100% sold on that. I am going to see about a longer pushrod and see if that clears up the noise.
Old 01-21-2010, 01:41 AM
  #28
TURBHOE's Avatar
Anassix. what kind of oil pressure do you have now that you disabled the DOD? i was told that the DOD oil pump would pump too much oil for my motor (found one cheap) and that it could cause issues. now that you have no more DOD did the oil press rise?
Old 01-21-2010, 06:23 AM
  #29
smokeshow's Avatar
No, oil pressure stayed about the same. If anything I think a high volume pump would be better. This cam isn't too aggressive...I know people have installed it before and come out with a quiet engine. I'm from Tucson, AZ btw.
Here's the video...it's really hard to hear, but it's there.
Old 01-21-2010, 01:52 PM
  #30
Where's the Beef?
That's pretty loud
Quick Reply: ridiculous ticking
