Ring gap/forced induction recommendation ***carnage pics inside***
Old 03-19-2012, 06:10 PM
  #31
Lucille's Avatar
Aggressive is the .35 ring gap they ran in their drag motors back in the 80's.
Old 03-19-2012, 08:31 PM
  #32
Mod with training wheels
smokeshow's Avatar
Originally Posted by AKlowriderZ71
I'm all ears, what's your suggestion?
Honestly stock is probably fine. Unless you get a freak motor and twin 76mm turbos and put out 1200hp lol...then things might get a little hot. Only thing to keep in mind is the more power you make, the more heat the cylinder will see. But for like 6-700hp, stock is likely no issue. Lower temp t-stat would help make up for lack of a ring gap if you are pushing it power wise.
Old 03-20-2012, 12:55 AM
  #33
11 Second Hall Moniter
AKlowriderZ71's Avatar
I don't feel like swapping my thermostat 2 times per year though. And 160* thermostats suck ***** up here in the winter.
So, I have this urge to push things, like up the boost to 13-14 psi. And I have this nitrous kit that's just sitting there, staring at me every day... You still say stock ring gap? That's not sarcasm, that's a serious question.
Since we're on the subject, what are the drawbacks of a slightly wider ring gap?
Old 03-20-2012, 12:58 AM
  #34
Also, this engine is completely torn down at this time. When I reassemble it next week, I don't want to know that it's "probably fine." I want to KNOW that it's fine, and will be able to survive all the stupid abuse that I'm going to put it through.
Old 03-20-2012, 01:02 AM
  #35
smokeshow's Avatar
I understand. No harm in opening up the gap more, it might burn a tiny bit of oil though. My point is that you'll likely exceed the limits of the stock engine before you have problems with rings, provided you keep temps under control.
Old 03-20-2012, 01:16 AM
  #36
gonzo 6.2's Avatar
you had a freak detenation like someone said here.toss in a new slug and ring set, check gap but dont mess with it if its like the others.Keep in mind ,folks have put many a radix on brand new engines and never had an issue if they left them stock with good gas.So new tight engines handle boost, so should your high mile engine just but it back to what it was and run the hell out of her.
Attached Thumbnails Ring gap/forced induction recommendation  ***carnage pics inside***-dscf0002.jpg
Old 03-20-2012, 09:09 AM
  #37
ak2007r6's Avatar
More boost?? Nawz?? You really want to get kicked off the track don't you?? LOL
Old 03-20-2012, 09:31 AM
  #38
Swerve7rpm2000's Avatar
ugh that sucks to hear.... is it possible you got some really bad gas too? You my friend should be happy for the 100$ fix!!
Old 03-20-2012, 11:49 AM
  #39
It is possible, actually. I just filled the tank the day that this happened.
Old 03-20-2012, 11:50 AM
  #40
Quick Reply: Ring gap/forced induction recommendation ***carnage pics inside***
