Ring gap/forced induction recommendation ***carnage pics inside***
#92
From Hot Rod:
Our guinea pig was a 5.3L truck motor, while the punishers were a pair of 76mm turbos from CXRacing plumbed into a homemade twin-turbo system. When we got it, the engine was a grimy core from a junkyard. We took it apart and found a pretty significant rust spot in the No. 8 bore that a ball hone wouldn't remove, but it was halfway down the bore so we thought, What the hell, we're trying to kill this thing anyway. It won't matter. The motor was reassembled using the original crank, rods, flat-top pistons, rings (a little rusty but they cleaned up OK), and bearings.
****The sole modification to the short-block (at the advice of Jerry Stetler from Ace Machine) was to increase the gap of the top rings from 0.015 inch to 0.028-0.030 inch (we reused the original rings). The second (factory gapped at 0.028 inch) and oil rings were left untouched.****
Stock GM LS Engine - Big Bang Theory - Hot Rod Magazine
One thing people didn't mention (at least I didnt see it) is ring thickness and how much of the ring land that top ring filled, this could be an issue too due to expansion when heated. If ring was too thick and ring land got narrower, that could cause it to break the top of upper ring land, right?
#93
I'm trying to find out what works, and what doesn't. It's an L33, 9.95:1 CR, 799 heads, trucker cam, MP112 at 10-11 psi, likely to see 14-15 psi eventually. There's also a possibility of some nitrous later on, but probably with 10-11 psi.
Anyways, for stock pistons, and stock rings, on a stock bore diameter, what's a good ring gap? Mine are currently at .020", and here's the aftermath.
On a good note, everything else is in great shape!
I dont think there is an end all product thats good for all setups, its either you build for nitrous plus other mods or just the other mods.
Input would be appreciated.
#95
Waking from 3 year slumber, but the fact that they used the flat top pistons as opposed to the dished won't affect that preferred ring gap for turbo 5.3L application?
Also, I thought different material piston rings altogether along with some extreme ring gaps is recommended for nitrous.
#96
Any noticeable oil consumption along with negative effects on wideband or egr/emissions?
#97
#98
It uses almost a quart of oil between oil changes, 3000 miles or so. EGR has been deleted a long time ago. No problems that I know of.
I'm not sure about setting up rings for nitrous. I've never done a nitrous motor, the only power adders I have experience with is superchargers. And a couple of turbos.
Raggedz71
07-29-2016 10:20 AM
Dezert1500
07-30-2015 02:51 PM
