Rocker Questions - Who has busted them?
I think you got your pushrod geometry all fucked up. You had the heads off, and got them milled. You need to find out if whoever put them back on compensated for that with the gaskets, then get ahold of a pushrod length checking tool, and determine what length pushrods you need. The stock length is 7.400.
Preloads are .020 to .060 on stock setups and previous post about no lash adjustment is correct. Just torque to 22 ft lbs. FWIW, my 1.85:1 rockers use a Crane Cam 7.250" pushrod due to the geometry change...
Crane Cam 7.250
Good Luck
Crane Cam 7.250
Good Luck
LS1Tech Sponsor
Crane Cam 7.250
Good Luck
Crane Cam 7.250
Good Luck
