Rocker suggestions
Old 05-31-2008, 10:23 PM
jakebdb56's Avatar
Default Rocker suggestions
I'm starting to look around for some rockers to go along with the new cam eventually. I messed up one of the rocker bolts putting the stock cam back in a few months back so I figured that if I'm going to do springs again with the new cam I might as well get better rockers.
I've heard a lot about the Harland Sharp roller rockers, but have never run them myself.
http://store.summitracing.com/partde...7&autoview=sku
New cam is going to be a custom Comp grind, probalby a 218/224 .570/.570 110LSA on XER lobes.
Thanks in advance,
Jake
Old 05-31-2008, 10:36 PM
gao8302's Avatar
I just put the Harland Sharps on my 370. They are worth every penny IMO. They are a direct fit.
Old 06-01-2008, 01:14 PM
Doobie's Avatar
I used the Comp pro magnum rockers and they did not fit under the stock rocker covers as advertised. I had to mill the casting dimples off from bottom of cover and remove the PCV baffle. Not a simple plug and play.
Old 06-01-2008, 01:26 PM
ZZebes's Avatar
the harlans that everybody talks about are harlan upgrades they take your stockers and replace the trunions with roller trunions and ARP bolts
Old 06-01-2008, 02:32 PM
jakebdb56's Avatar
where can you get them?
Old 06-01-2008, 02:35 PM
ZZebes's Avatar
I don't remember off the top of my head but they have approved dealers you have to go through
Old 06-01-2008, 02:39 PM
jakebdb56's Avatar
ah ok, would it just be better to get the whole set for 380 from the link above?
Old 06-01-2008, 02:40 PM
ZZebes's Avatar
I like the stockers, they don't get much lighter than that and with the harlan upgrade there damn near indestructable
Old 06-01-2008, 04:08 PM
jakebdb56's Avatar
All i gotta do now is find out how to get them upgraded
Old 06-04-2008, 06:41 AM
dhpro's Avatar
Is it not best to go with a shaft mount Rocker setup? I think Jesel makes one, altho I don't think its any bargain! ($800+?). R/
Quick Reply: Rocker suggestions
