Roller rockers and UD pulley/balncer?
I checked the wipe pattern across the tip of the valve with my new cam (.612 lift) and it's fine. Don't believe everything you read. Also the heavier balancer will dampen and absorb harmful crankshaft harmonics better than an aftermarket unit will as well. It's your call.......
These motors are internally balanced and the crank pulley is just that, a pulley. I have a friend with a LS motor Camaro and when he did away with his air conditioning he had the back half of his crank pulley machined off where the A/C belt rode saving a whopping eight pounds off the front of the motor. He has been running it like this for 2 years with no problems!!
It's not just a pulley, it has a rubberized ring around the outside seperating it from the inside. It does dampen and absorb crankshaft harmonics. No engine has zero crankshaft harmonics
Ohhh, I wasn't aware of that, I thought it was all done internally. So the aftermarket pullies, do they have the rubber inside them, doesn't look like it? One would think that an aftermarket pulley would create increased crankshaft harmonics...I don't like the sound of that.
the pulley functions as a harmonic damper, which has nothing to do with static balancing. Its not "just a pulley".
