Which rotating assembly is best??
Old 02-16-2009 | 02:42 AM
Sierra1320's Avatar
Default Which rotating assembly is best??
From what I've read and done searches on I cannot find a definitive answer to the question. Scat, Eagle, Callies, Lunati, Wiesco, etc... Now I know this is an extremely complicated question since a lot of guys mix and match different cranks, rods, and pistons from different makers, but what is the best quality of all of those parts all around? I am wondering what is the best rotating assembly in terms of reliability, quality, strength, and ability to withstand high horsepower applications for LSX engines?
Old 02-16-2009 | 10:17 AM
ZO6Ted's Avatar
Of those mentioned, I would think Lunati, but at a price.
Old 02-16-2009 | 10:22 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Nothing wrong with eagle crank and rods, for pistons, Wiseco is on my **** list and so is JE, I could write a book on why I dont like them so dont pick them.
Old 02-18-2009 | 05:40 PM
Neverdone's Avatar
^ So what would your piston choice be and why?
Old 02-18-2009 | 06:17 PM
built408's Avatar
diamond pistons, and callies crank and rods, either compstar or magnum
Old 02-18-2009 | 06:20 PM
Sierra1320's Avatar
I know the callies compstar is their "budget" crank, but how much power can that crankshaft hold with a good set of their rods? How much for the magnum too?
Old 02-18-2009 | 11:38 PM
2004SSS's Avatar
depends on how much power, after about 1300-1500 hp you should go to a an aluminum billet rod which are huge bucks and need to be replaced every so often.
crank , there are a few places that make custom billet cranks and they are stronger than an off the shelf crank but cost huge bucks as well as take forever to be made. however with the lower priced forged cranks dont usually have problems when pushed.
pistons is alot of preference.
on a side note , i wanted strong stuff for my build 1200 hp area.
i went with a callies dragonslayer crank , lunati pro billet connecting rods and some custom coated diamond pistons.
blown02408
10-01-2015 02:06 AM
chopperloco
09-28-2015 09:40 AM
sTNT971
09-26-2015 05:22 PM
g6t6o
09-26-2015 11:57 AM
USMCvet0311
09-04-2015 10:43 PM
