safe rpm on a LQ9?
safe rpm on a LQ9?
How high can I shift a 6.0 LQ9? The motor is stock bottom end with ARP rod bolts. With my cam and intake set up it feels like I could go past 7200 and still make power. My 1-2 shift just goes quick and I think I will make power above 7200 but how high can I go?
i agree with nonnie, eric i changed my shift points saturday, cant tell ya if it helped or not i needed another run, but by the data log it did shift at 7k, plus i am still slipping off the line!! plus i am still having a slight voltage problem, and cant figure it out, might have to go with a 200 amp cause of the EWP
