seafoam in the oil?
#21
Originally Posted by 99silveradoSS
When sucking it up in the booster line and running it, can the crap out of the combustion chambers clog up the cats?
I don't think it will be an issue. After doing this go out and really drive the truck, get it nice and hot for a good half hour ride on the freeway or something. That should burn up all the residual stuff left over.
#22
Originally Posted by Soon2bSpooled
the can only recommends 1/3 of a can through the booster line but a 1/2 should be fine, let yoru engine suck it through alternating seafoam then air until however much you want is gone then turn it off. it says to let it sit for 5 minutes but i usually sit it for an hour, start it up, (make sure the windows are up) and be prepared for nasty phone calls. after it smokes a while go drive it around kinda hard through all rpm's to clean out the system
1/3 can haah. who reads the instructions anyways. i dumped a whole can in mine. looked like the car off the movie uncle buck. runs good to.
#23
Hey Fogle, Did It Backfire About Ten Seconds After You Turned It Off, And Made Everybody In The Parking Lot Duck Like You Just Shot A Gun? Lol!! Ok, So Run 1/3 To 1/2 Can Through The Pcv & Let It Idle For A Lil Bit, Then Go Driv It.....ok Cool. Thanks For The Help Everyone....
#24
no it just smoked like a freight train. i shut it off for about 10 minutes then drove it down the road. seems like it idles a little nicer now. im prob. going to run some thru the gas one day.
lukn4trbl355
10-21-2015 11:19 PM
lxcoupe
09-25-2015 12:36 PM
69z-28
09-21-2015 07:31 AM
