Shoud i swap the cam or not
Old 03-22-2010, 09:59 AM
  #21
la meanred's Avatar
Originally Posted by dirt track racer 81
Get headers on, get it tuned right, and get some tires that will hook and 12s should not be a problem at all.. That motor needs to breath specially with a cam like that and stock manifolds are killing that thing.
There shorty headers but yeah im going to put the lt on as soon as i have time.
Old 03-22-2010, 10:03 AM
  #22
la meanred's Avatar
Originally Posted by Preston129
There's no such thing as too big of a cam, just too low of a stall!
I wouldn't say the cam is too big for the engine, but I would say it's on the verge of being too big for a heavy truck, especially one you dd. If it was track only, the cam would probably work with an even higher stall, but for the street it's up to you how much "driveability" you're after.
How does the current engine/stall combination suit your daily driving? If you say "sluggish till 4000 rpm, and only manage 7-10 mpg" then I think you can see the writing on the wall...
I think your combo really favors track use, which will always be at odds with driveability and fuel economy, but it's all up to how much of one you want to sacrifice for the other
i really dont mind the stall its a 3800 circle d multydisc with the l80 but i guess the re tune and the crank pulley and longtubes shoud help me more . i need to get the pulley to does the pulley help a lot.
Old 03-22-2010, 08:47 PM
  #23
BlownChevySS's Avatar
I have a cam very similar I was gonna put in and got advised against it. It's a Comp 238/242 .605/.610 114lsa. My motor guy told me it would suck on the bottom end and I could make way more power with a smaller cam, so that's what I plan on doing. Plus I don't want the 7mpg.
I have a set of 243s I am gonna put on my lq9, but stock, those motors came with 317 castings
Old 03-22-2010, 09:31 PM
  #24
la meanred's Avatar
I think the reason is that u need a bigg stall to get the power to the wheels i got a 3800 but im probably going to get another truck and park this one .
Old 03-23-2010, 09:57 AM
  #25
I got the same stall speed too. I didn't care at first because I figured most of the time I'd be doin 70 on the highway, but stop n go would kinda suck with a 6k lb truck when I think about. I'm used to having power on the low end courtesy of the radix I used to have.
Old 03-23-2010, 11:11 AM
  #26
11 Second Truck Club
MPFD's Avatar
Whats the minimum gear you guys would run with a cam in this size range? 3.73 seems kinda high for a cam like that? What about with a 150 shot, would the taller gear be a benefit if you know your making the hp numbers, or would you want it spinning more RPM in third on the big end.
Old 03-26-2010, 12:47 AM
  #27
la meanred's Avatar
Well my friend has a 4do with 4k stall and he got 430s in the back and said the truck felt better.
Old 03-29-2010, 05:14 PM
  #28
Givnasty's Avatar
Sup guys I'm rockin' an LQ4 with catless Corsa Sport exhaust, AEM intake, Nelson tuned. I'm not very up to speed on cams. Why are they so difficult to install? How are you guys able to swap cams so often?
Old 03-29-2010, 07:26 PM
  #29
dry_kill's Avatar
not difficult, just very involved
Old 03-29-2010, 07:30 PM
  #30
dlt76028's Avatar
Seems like pretty good times on street tires and being ext cam and no headers..
Quick Reply: Shoud i swap the cam or not
