Should I get my torque converter loosened up a bit?
Ok so yes I know I need gears and when I do then I'm going 456's but that won't be untill next year lol.... For now I have the trans out and my torque converter is being sent back to Dave @ yank to be cleaned up. I'm debating if I should have him restall it while it's there. And if so how much more should I go?
PT's Slowest Truck
Your set up doesn't need more converter, actually, with that cam in a 6.0 you would be fine with less converter and still be well matched. As mentioned, more gear or less tire is the way to go. If you plan on going wild with the camshaft, then I'd have the converter re-stalled, but if not, I'd just start saving up for some gears and roll with it like it is in the meantime.
Laid Back
Have you tried 4wd launches on the street? My truck cut a 2.0 60ft before I put new heads on. Now that I can break the tires loose in 4wd on the street, I figure that I should be dropping that 60' pretty good.
Your 1.9 60' with a truck that is smaller and lighter(and prob. more powerful) than mine indicates that you need gears bad.
