Should I upgrade rod bolts/oil pump/chain?
I picked up a 02 5.3 with 77k on it out of an avalanche for $350 bucks to run in my 2000. Im got a 216/220 114lsa cam, ls6 springs and hardened push rods sitting on the selves so Im going to put that in it but didnt know while I had it on the engine stand if I should put a few more parts at it.
-Should I bother with rod bolts?
-LS6 ported oil pump?
-Timing chain?
I dont plan on running big boost with it but maybe some cheap insurance? Then again it is only $350 dollar motor? The only one Im really considering is the oil pump seeing if something does happen, I dont want to ruin the turbo.
Im just trying to get my ducks in a row that way if I need to order somethin, Ill have it there waiting for me. Just seeing what your guys thought are.
-Timing chain?
High on diesel fumes
I wouldn't bother on a stock motor. Just gonna be a waste of time and money.
Rod bolts are good for high RPM like KySilverado said.
Oil pump is gonna be a waste of money on a stock motor. I was running a factory pump on my stroker with no issues.
I've never heard of a timing chain breaking on one of these motors either.
Considering what I paid for the motor Ill prolly just leave it be. I just figured seeing I was already going to have the cam out and changing oil pan, that would be the time to change these parts.
Thanks for the input guys.
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
