Should a lifter do this?
I have had a very bad valve train noise at start up and then it goes away after 3-5 seconds, but even then I get some pretty heavy valve train noise. I took the heads off and one of the lifters did not comeout with the tray, as I went to take it out it was stuck in the lifter bore, I had to use pliers to pull it out. Could that thing have been stuck in there and only when it finally pumps up it will move? What do you guys think?
Ok then I was kinda thinking that, Trying to think as to what would cause that thing to get stuck like that? I wonder if I should clean up the bore put in some new stock lifters and call it good. I really don't want to take the oil pan down to check that damn o-ring?
High on diesel fumes
Scoggin Dickey has them www.sdpc2000.com
You should be fine with the same pushrods. The stock LS7 lifters require the same preload as the LS1 lifters.
well I should have a new lifter kit waiting for me at the dealer today, not bad $105. All the ls lifters have been superceeded by the ls7 style lifter..or thats what I was told be SCD. I will replace that oring tonight, Im running out of things to replace.
