Sleeving a 6.0
Sleeving a 6.0
Any one had a 6.0 sleeved? My cousin in texas has his 6.0 at a machine shop and they dont want to sleeve it they want to just bore that one cylinder out and leave the rest standard bore.
No way Jose. That's rough as he'll on rod and main bearings. That one uneven stronger cylinder will beat the hell out of the entire rotating assembly not to mention the one heavier piston. Will be damn near impossible to balance as well. I'd just bore it and go bigger or resleeve that one hole. I've seen that done with no ill effects. Are the cylinder walls beat up that bad??
I completely agree this will cause a lot of balancing issues plus that hole will have bigger CI than the others have more compression and run leaner plus he's spraying it. Its a veru bad idea in my opinion
To the same as whatever the other seven are. I guess the machine shop screwed up one cylinder when they were boring it to make my 408.
No, I didn't get one humongous piston to emulate the sound of a hot cam at idle.
Good Luck!
I only paid 1700 to get my 6L bore with new pistons, .030 bore, bearings, ARP rod bolts.
GMCtrk
18
10-06-2015 03:48 PM
Cammed4ever
09-30-2015 03:38 PM
