SLP 1.85 rockers on LQ4
What is the verdict on SLP 1.85 rockers, good, bad, other? I have a set that I plan on putting in my new LQ4 engine for my 00 truck with 918 springs and wanted to know if there were any horror stories before I went ahead with it. I will retain the stock cam/heads, pistons, ect. and the only mods will be minor. LT headers, ported throttle body, 180 stat, EFI live tune by myself. The truck is my daily driver, it won't spin more than 6200 rpm. Sound OK?
They work fine no problems and they add about 10 to 15 hp over stock.They only add lift not duration but you need to be careful using them with an aftermarket cam,because you can cause coil bind by exceeding the rated lift of your valvesprings.Plus they accellarate the ramps of your cam,which is'nt an issue with a stock cam.
KINGCYCLES
10-02-2015 10:21 AM
