stage 2 ls6 heads on 6.0
Old 01-15-2007, 08:02 PM
9 Second Truck Club
tarinitup's Avatar
Default stage 2 ls6 heads on 6.0
I just sent an offer to a guy on ls1tech about a pair of heads for my 6.0. Question is how well these heads will work on a 6.0. What will they bring the compression up to if I put flat top pistons? Are they worth 600 dollars?
Patriot Stage 2 LS6 cnc heads with less than 3K on em have the gold springs, larger valves 59cc chambers and extra porting done to heads.
Old 01-15-2007, 08:04 PM
Mr. Obvious
nightrunner's Avatar
im not much on heads but i think ive seen heads like that go for 2x that amount...
Old 01-15-2007, 09:11 PM
onebadrubi's Avatar
Those are only 300$ new. 949$ assembled new!
Its up to you but I personally on the deal you are talking about would go new. Those have been miled a good bit if they are 59cc. They are 64cc stock. on a lq4 that will gvie you 10.5:1 and lq9 that will give you 11:1. If they have been miled and you have an lq9 your gonna be pushin it to run on pump gas and stock gasket.
Old 01-15-2007, 09:15 PM
Mr. Obvious
you mean cnc'd ls6 heads are goin for under $1k assembled? #317 cnc'd by WCCH are over a $1k
Old 01-15-2007, 10:31 PM
onebadrubi's Avatar
http://www.patriot-performance.com/w...p?x=1&DID=1225
Old 01-16-2007, 09:51 AM
Zick's Avatar
Those are the Stage 1 heads, Tarinitup said Stage 2 which would be these; http://www.patriot-performance.com/w...05234&DID=1225
At half the cost of brand new I'd say it's a good price.
Old 01-16-2007, 10:03 AM
High on diesel fumes
thunder550's Avatar
Sounds like a good deal, I paid $1400 for my PRC stage 2.5 LS6 heads assembled from TSP. The only thing that would concern me is how much they have been milled.
Old 01-16-2007, 10:43 AM
tdrumm's Avatar
They may not have been milled. If you read the link, they are a "035" head that the chambers have been welded up. They say that custom chamber sizes are available.
Old 01-16-2007, 10:55 AM
thunder550's Avatar
When did the LS6 get an 035 casting? I thought they were all 243's.
Old 01-16-2007, 11:04 AM
FormerVendor
Richard@WCCH's Avatar
The only two LS6 casting numbers I've ever seen are 799 and 243. The 799's were a pre production head and later updated to the 243 casting. The 035 is a 6.0l casting. Basically the same as a 317. My understanding is the welded chamber heads started life as a 6.0l head core. After welding and machining they should work just fine.
Good luck with your head mods. LS6 heads are a great way to go, just watch out that you don't build too much compression.
Richard
Quick Reply: stage 2 ls6 heads on 6.0
