stage 2 ls6 heads on 6.0
The deal on the Heads went through and now I have some more questions. Heads are stage 2 ls6 with 59cc and the pistons I ordered are 16cc dish pistons. The guy I ordered the pistons from told me that set up would give me around 10 to 1 compression. Is that correct? I wanted 10.5ish compression but that was the best match I could find with 59cc heads. Machine shop said no bore was needed so pistons are stock 4'' bore. I guess when this comes together it will be practically the same as a forged lq9.
Originally Posted by thunder550
I messed around with the calculator and I'm going to mill the heads .030 to 55cc and that should put me around 10.2 and a little higher if I go with thinner gaskets.
FormerVendor
Be careful about milling the heads a bunch more. The head core's deck thickness is getting thinner and thinner. That leads to failed head gaskets or torched pistons. To get to 52cc from the stock 65cc LS6 head we'd have to mill .078". That's way too much in my opinion. It'll only lead to trouble down the road...............
Good luck with your newly acquired heads. If the prep work is halfway decent your engine should run pretty sweet.
Richard
Richard
Richard
Richard
FormerVendor
Now that makes better sense. I missed tdrumm's post about the welded chambers. Welded combustion chambers will reduce the volume nicely and help airflow in most cases. Milling .030" will probably net you 5cc of volume. I don't know what your piston deck height is so I'll go with zero.
Milling 5cc will pump the c/r up to 10.24:1. I see that milling 3cc will get you to 10.02:1. I use .006" per cc of milling so removing .018" will get you to 56cc.
Good luck,
Richard
Good luck,
Richard
