stock crankshaft wit after market rods and pistons
Old 11-27-2007 | 06:39 PM
xdanny510x's Avatar
Default stock crankshaft wit after market rods and pistons
would it work if i use stock crankshaft and use after market rods and pistons on the 6.0 im going to swap into .. would it hold up ...
Old 11-27-2007 | 06:43 PM
Derek @ EDO's Avatar
FormerVendor
the crank cold hold around 1k HP so your limits will most likely be based on the rods and pistons (700-800) HP for a good forged set.
Built correctly, Hell yea it will hold up!
Old 11-27-2007 | 06:58 PM
nightrunner's Avatar
Mr. Obvious
correct. most times the only reason for a forged crank is to get a longer stroker for 402/408s
Old 11-27-2007 | 07:08 PM
FormerVendor
Yep or to save a little weight!
Old 11-27-2007 | 10:11 PM
Blown06's Avatar
8 Second Truck Club
I'm using a stock crank, eagle H-beam rods and mahle pistons. Seems to be holding up just fine.
Old 11-28-2007 | 01:47 AM
FormerVendor
Well after reading this!
https://ls1tech.com/forums/showthread.php?t=821367
looks like the stock crank can withstand over 1400 HP
5.3Okasai
03-09-2022 02:07 PM
greedygenius
09-03-2015 07:51 AM
Ammadien
07-22-2015 09:50 PM
black6spdz
07-16-2015 02:32 AM
4B11T
07-13-2015 04:48 PM
