Strange Sounds?
Old 05-17-2009 | 08:11 AM
Basool's Avatar
Default Strange Sounds?
Hey guys i installed a cam and 4.10 gears on my avalanche but still haven't got the chance to tune it...while i was driving home i noticed a whining and ticking sound when i let off the gas at 60 mph? Anyone have any idea if this is normal?
Old 05-17-2009 | 08:14 AM
budhayes3's Avatar
PT's Slowest Truck
What brand of gears did you use, the whining may be characteristic of them. As for the ticking, it may also be characteristic of the aftermarket cam. What springs and pushrods did you use? Cam specs? You could always re-check the rocker arms just to be safe...
Old 05-17-2009 | 08:19 AM
Basool's Avatar
its actually not my truck...but it has richmond 4.10 gears...Patriot Gold springs...trickflow pushrods...and a GT11 cam...
Old 05-17-2009 | 08:26 AM
JakeBrakeIH's Avatar
do u have headers? if so it could be the sound of the valves slamming shut and ur not used to it...the valve springs themselves are very loud as well...
Old 05-17-2009 | 08:30 AM
Basool's Avatar
yea he has pacesetter long headers with a y pipe..(no cats) the ticking is probably from the valves but the whining sound...thats irritating
Old 05-17-2009 | 08:55 AM
Basool's Avatar
he has pretty much the same mods as me...but im changing from my GT11 to a Thunder racing custom grind..
Old 05-17-2009 | 10:32 AM
budhayes3's Avatar
PT's Slowest Truck
I've heard that the Richmond gears are noisy, so it may be characteristic if the gears are set up right.
Old 05-17-2009 | 01:35 PM
Basool's Avatar
Yea its seems to have a whining sound to it..but there nice lool
Old 05-17-2009 | 04:38 PM
ragu3's Avatar
Default better look
Ive set up richmond gears for years with no sound ect.. Better pull the cover and inspect the contact pattern before its too late. usually the whine can be corrected if not run too long
Old 06-08-2009 | 02:32 PM
Basool's Avatar
Does the whine affect its performance in any way?
lukn4trbl355
10-22-2015 12:19 AM
03sierraslt
14
10-09-2015 06:53 AM
Infernohoe
48
10-02-2015 11:25 PM
Wolftrk99
10-02-2015 09:17 AM
Rockrz
09-29-2015 10:07 AM
