Stripped rocker bolt- Helicoil or tap?
Old 05-04-2009, 10:00 PM
9 Second Truck Club
tarinitup's Avatar
Default Stripped rocker bolt- Helicoil or tap?
I installed my head today and when I was tightening the rocker bolts I overtorqued one of them. Is it safe to clean the threads and see if it holds to the 22 ft lbs or should I helicoil it with the head still on. Who's helicoiled one of these before and how hard was it?
Old 05-04-2009, 10:01 PM
Banned
TexasPainter's Avatar
heli-coil. dont risk it. make sure you loc-tite 693 the helicoil.
Old 05-04-2009, 10:04 PM
Wearin' da big hat
00ChevyScott's Avatar
heli-coil will be best option.
sonoma43's Avatar
are the threads actually stripped, or did you just tighten them a bit to much?
if material is missing from the head then a heli-coil is the best option
Old 05-04-2009, 10:05 PM
9 Second Truck Club
tarinitup's Avatar
just overtightened. I've never done a helicoil, is it hard?
Old 05-04-2009, 10:06 PM
Baltimore Whore
Mangled03gmc's Avatar
Heli it or tap it out to the next size bigger and roll with it. If you do heli it use LOC TITE
Old 05-04-2009, 10:08 PM
sonoma43's Avatar
a good heli-coil requires you to drill out the hole to a slightly larger size and then put in a heli-coil, to do it the right way anyway.
if the threads are still good then just put some lock tite on them and it should be fine!
Old 05-04-2009, 10:18 PM
Wearin' da big hat
Old 05-04-2009, 10:20 PM
How do I change this text
Wilde Racing's Avatar
CAT-zert FTW, Heli-coil SUCKS..... I'd go to the next size up though.....
Old 05-05-2009, 02:05 AM
charcold-bowtie's Avatar
should have let jesse do it. then blame his ***
Quick Reply: Stripped rocker bolt- Helicoil or tap?
