sts cam suggestions
you see what he ran in his stock 6.0?
![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
I AM A MOTHERF*CKER
On an LQ9 for street duty and a low boost sts setup I'd run something in a 220ish/216ish range on a 114lsa, but honestly with a "non-maximum effort" turbo setup cam choice is much less important than in an NA setup. Get a good, 0 overlap single pattern or reverse split and slap it in.
Hunt&Fisherator
reverse split Erik??
please school me LOL I always have believed that larger exhaust duration/lift would help spool time slightly since there are 6.5 miles of tubing before the turbine. This is the same concept as front mounted but maybe not AS critical simply because the much shorter hot side.
The cam I have picked out for my setup is a 219/229 .59x/.6xx 114+2 custom grind, theres currently a GT2-3 living in there.
ZO6Ted
08-12-2015 07:50 PM
