Swapped in a 5.3, 862 Heads question...
We, and most on here will recommend checking pushrod length instead of guessing what length you need because variances in all parts of the valvetrain could be off/different than someone elses setup (even if they are using the exact same parts).
Basically when it comes down to what can cause these differences(I will name what I can think of off the top of my head, if anyone can think of something I have missed please feel free to chime in):
The deck surface on GM blocks can differ from block to block, which can cause a different pushrod length.
The cylinder head deck can vary from head to head (be it GM, aftermarket, reman, etc...), thus changing pushrod length.
Valvestem height due to either a valvejob, or different stem length can cause the need for a different pushrod.
Different camshafts with different base circles can require different pushrod lengths.
Using different lifters that require different preloads can change pushrod length.
GrooveCityZ71
08-31-2015 01:05 PM
