Tbss/nnbs intake on 01 5.3?
#22
11 Second Truck Club
Its regulated inside the filter. There is a relief valve inside the filter that uses spring pressure to keep the return closed off till it reaches 58 PSI then it allows excess fuel not needed to maintain 58 PSI to return to the tank. I had to have my injectors scaled over to run off a constant fuel pressure instead of using variable pressure. The pump on our older trucks is a constant pressure pump, Its voltage or output is not variable. The regulator on the rail allowed more or less fuel to return back to the tank from the depending on a vacuum signal. This setup is ok if you are running NA like mine, but not as good of an option for boosted apps. Here is a picture of the inside of the vette FPR/fliter. The fuel comes in the top on the back side, it is filtered and allowed to pressure up the rail. The return fuel is feed back the the center line after the pressure in the rail has been met at 58 psi. If your rail pressure drops the return valve closes and the rail getss full pump volume to make up the difference till pressure of 58 PSI is reached again. It's not really fast enough responding setup for the high volume fuel system needed on boost. But Im only gonna run NA and set up a dedicated enrichment tank for my Spray.
N E 1 ever heard of a fuel filter w/internal regulator failing? - Z06Vette.com - Corvette Z06 Forum
I wouldn't use any cheaper filter then Wix. The cheaper the filter the slower it will be to respond. Don't know how makes the Micro guard.
#23
Interesting, ya I would not run that with boost.
#24
The biggest issue with it is having too high of pressure, not too low. One of the mods talked to me and said he saw almost 70 psi at idle one time before he ditched his. But as you boosted guys know you need high volume fuel systems and this setup is not ideal. It can't return enough fuel fast enough when you are running a giant volume pump or added inline pumps.
#28
Guy I sold it to used the factory injectors with it. Unfortanatly thats the only pic I have deleted mostly all I remeber using sapcers for the fuel rails and I trimmed the intake down where the crossover tube was. It was the plastic that sticks up from the factory
