Texas Speed Cam question
Anybody out there have a texas speed 224r cam? Id like to get all the specs off the cam, and preferably the grind number from COMP. If anybody can help me it would be much appreciated. Ive called texas speed and they will not release the grind number to me
![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
Just don't ask Comp to grind a TSP 224r
Tell em you want the lobe numbers:
3722 intake / 3722 exhaust
And choose the LSA you want and the ICL
They can't deny selling you it because the lobe numbers are listed under there XE-R lobes TSP just chose to use them. The only difference between your cam and the TSP cam is that the box will not say its a TSP 224r
Bring on the flames cause I got burned to the ground on the Ram forums for telling guys this about certain cams that were done through Comp.
Your welcome...
Jay
Your welcome...
Jay
