Are there any good kits to convert 2 bolt main to 4 bolt?
Originally Posted by Silent Thunder
I was told that the block came out of a 94 chevy. I checked the #'s on the block and went to mortek.com to verify. I want to go to a 4 bolt because I was informed that you must have a 4 bolt to build a 383 stroker. Is this true? Someday I plan to add a charger but that will be a ways off. My goal is to have about 375-400rwhp, all motor. Who knows what it will be after the charger install.
450fwhp with a 150shot on a 2 bolt main with a girdle. All is well and if anything is going to fail it sure as hell won't be a main. Rings, pistons and rods will definatley go first.
Think about this, you have and old block, that you're going to spend $500 having it bored, honed, decked etc. Another couple hundred to get it converted to a 4 bolt. You might as well get an aftermarket block that's ready to go with the potential for more cubes.
Originally Posted by brian4.8
not being funny but bluecajun is right, I have never seen a crank fall out of a block!!! 2 or 4 bolt
