Is there anything wrong with my main caps? pics inside
Well I tore into the 6.0 a few weeks ago and the main caps have some bluing blacking discoloring to them as well as the bearings. Is this normal? the motor was high mile and I bought it as a running motor. I was told it is from the heat transfering through the bearings. Some have said no big deal its normal and others have said I need the block line bored or buy new caps to fix. What is your input?
Tribe Shaman
it looks burnt to me.
something got hot.
was it getting enough oil???
just to be safe i would have the machine shop do an alignment check
on the mains.
also blow some air through the oil passage way and look for trash.
something got hot.
on the mains.
FormerVendor
Bearing look perfectly fine, its not chewed up or blue.
Just have the line bore checked, if it needs to be honed then hone it.
If it does need some honing make up the difference in the new bearings.
Id put some Calico coated bearings back in it.
You can tell from the oil staining that it is a high mileage motor, looks like normal wear and tear though.
The oil pan probably looks the same on the inside.
BigEd_72455
08-08-2015 04:49 PM
