Are these bearings bad? (pics)
Old 04-06-2011, 11:59 AM
THE-HOE's Avatar
Originally Posted by mechan12
yes you can if it is not scored and every thing must be clean ,clean,clean,
then you must check the clearance on the bearings after that you clean again and use some ***. lube then bolt it all back together to the right torque settings
donald
Ok, cool. Is there a place where i could do some research on this procedure. I searched on here but didnt really find anything about checking clearances.
Originally Posted by Callies Performance
ACL or Clevite
Thanks, I will look into those
Originally Posted by TXSZ66AVLANCHE
Typically no you can't just replace the bearings, you need to polish the crank and install over sized bearings. As a last ditch effort to patch it up while still in the truck? Go for it....after u have pulled all the rod caps, if nothing is obviously wrong with the rod bearing it will be pointless to replace em.
So your saying if all the rod bearings look good theres no need to replace them? what about if the main bearings look good also? Just strap it back together, or get new bearings to be on the safe side? Thanks for the help
Old 04-06-2011, 05:24 PM
THE-HOE's Avatar
bumpin it for tonights crew. Im still a little confused with replacing the bearings
Old 04-06-2011, 06:18 PM
11 Second Truck Club
fastrt's Avatar
if they all look good like those do, then thats not your problem. you may have a lifter problem, or something else. piston slap maybe.
Old 04-06-2011, 08:08 PM
454SuperSport's Avatar
An exhaust leak at the head/manifold can sound like a knock too
Old 04-06-2011, 08:11 PM
11 sec. Truck Mod
TIM Z's Avatar
How many miles on your lifters??
Old 04-06-2011, 09:04 PM
THE-HOE's Avatar
Ha yes i know this, i am nearly 100percent positive that its not that.
The lifters have about 4,000 to 5,000 miles on them they are ls7 lifters. The reason I did not think it was a lifter is because the sound does not come from one side of the engine more than the other. It sounds like its coming from the center of the engine, but I guess that the lifters are nearly in the center arnt they.
Old 04-07-2011, 08:54 AM
TXSZ66AVLANCHE's Avatar
If the rod and mains look good don't replace them as it would be wasted money. Have you pulled the cam to see what the lobes look like? Got a sound clip we can hear?
Old 04-07-2011, 12:13 PM
nickperry151's Avatar
free bump buddy
Old 04-07-2011, 12:44 PM
9 Second Truck Club
stock48's Avatar
Bearing looks ok, but usually a rod bearing will go before a main. Like said above you need to polosh the crank when instaling new bearings if you want to do the job right. Good chance this could be the oil pump Oring and have nothing to do with your bearings. Id check that first.
black00chev
08-28-2015 03:39 AM
chacho44
08-17-2015 03:36 AM
vipergtrdj
08-06-2015 10:19 PM
Ketis
07-23-2015 12:37 PM
Quick Reply: Are these bearings bad? (pics)
