Thinking of switching out camshaft to improve mpg please chime in
Old 11-19-2012, 07:37 PM
03sierraslt's Avatar
Originally Posted by TXSZ66AVLANCHE
To bring the power band down...so that the peak power potential is not in the stratosphere.
Lower LSA brings the power down, raising the LSA raises the curve. A 117lsa cam will make power at a higher RPM then a 112lsa. I agree with what you are saying as far as higher LSA (Less overlap) having a positive effect on mileage but it will also take away from the bottom end some. Something along the lines of a 115-116 is kind of a happy medium in my opinion.
Old 11-19-2012, 07:45 PM
TXSZ66AVLANCHE's Avatar
I disagree with your opinion that a higher LSA will make power at a higher rpm...but do agree that a happy medium of duration, lift, LSA will have a positive effect on MPH.
Old 11-19-2012, 07:46 PM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
A higher lsa will broaden the powerband but also move torque up in the rpm range, while reducing max torque.
A lower lsa will narrow the powerband and move torque lower in the rpm range while increasing max torque.
Old 11-19-2012, 07:51 PM
So why do u need a high stall converter with a (example) 224/227 .600/.610 112 lsa cam?? Based on the assumption that it will make more torque down low a high Stallman should not be needed.
Old 11-19-2012, 07:54 PM
I AM A MOTHERF*CKER
You missed the part about the narrow powerband.
Where the torque is in the rpm band is relative to the duration (and the cubes).
Disagree you may, however take a gander at this link. It explains LSA effects on the torque curve.
Technical Specs & Information
Old 11-19-2012, 07:58 PM
I AM A MOTHERF*CKER
This might also help (local version of that Comp chart from before Comp put it up plus a whole lot more).
Old 11-19-2012, 08:06 PM
spent21's Avatar
because a 224 112 lsa in a small cube, heavy truck needs a lot of torque to get moving, and since the power/torque curve has shifted from stock, a looser converter is needed to get the rpm to the point the engine is making power.
As for the OP, I have a 216/223 on a stock converter / 5.3 getting 18.5 if I'm lucky... of course, if I would back off of 80 mph, it would probably get a little better.
Old 11-19-2012, 08:12 PM
I dont remember the exact specs but these are close for comparison reasons.
Stock cam- 192/198 .476/.482 116lsa
If you only changed the LSA and left the other specs the same, a lower LSA would shift the torque curve down. Now in your question, yes the LSA is lower however you are also comparing a cam that has over 30 degrees more duration then stock. Adding 30 degrees duration will shift your torque curve up, a high intake duration will especially move the curve up.
Also as you know cubes eat up a cam so to speak, a big cam in a 4.8 is a somewhat mild cam in a 5.3 and tame in a 6.0
Old 11-19-2012, 08:40 PM
Ferocity02's Avatar
FWIW, I went from a stock 5.3 cam (114 LSA) to an LS1 cam (116 LSA) and lost quite a bit of torque down low, but there was a good increase in power up top.
And 18mpg highway ain't too shabby for a 6.0L. My 5.3L is averaging 16mpg
Quick Reply: Thinking of switching out camshaft to improve mpg please chime in
