Thinking of switching out camshaft to improve mpg please chime in
#22
I'm running the specs in my sig and get 21-22 mpg highway every trip. DFCO helps a lot imo. You could have blackbear get a little more agressive with the DFCO settings.
I'm interested to see how a cam swap will effect your mpgs. If you end up swapping, keep this thread alive with results!
#24
Stall will lower your mpgs if anything. I get horrible city mileage compared to my highway numbers because of my looooose 3200 converter. I wouldn't recommend a stall if you are in search of better economy.
#26
My current cam has yielded the best mpg (and dyno HP) to date, from Dallas to Waco and back using cruise control @ 70mph 23mpg. This is not typical though as I rarely use cruise, don't take off from a stop easy, and 70 is not my usual cruise speed lol my usual mpg is 16
#27
#28
Deceleration fuel cut off, it's a setting in the tune that can be adjusted by a tuner. It comes into play when you are decelerating. If you are going down hill and let off the gas, after a few seconds you will feel almost like you barely touched the brakes. That is DFCO kicking in.
