took off head got pics.
Old 03-03-2009, 03:18 PM
  #41
TURBHOE's Avatar
so, do you guys think i should get all the coolant out of the bolt holes?? it seems like it may be important.
Old 03-03-2009, 03:24 PM
  #42
WJ MARK's Avatar
did you do a compression check???? I pulled #7 out. Ring lands are broken but all intact. All the pieces are still in place, Just need a replacment piston and this bitch can go back together.
Old 03-03-2009, 03:27 PM
  #43
TURBHOE's Avatar
no, the heads are off and i'm waiting on parts. i'm currently finishing up my ls6 heads. soon as i get them finished and all my parts come in, this bitch is going back together. who would have thought, i'd take my only awd vehicle apart and it would snow 7-11".
Old 03-03-2009, 11:32 PM
  #44
WJ MARK's Avatar
Ha Ha, Im in Colorado and its been 70's all week, starting to think were in Arizona
Old 03-04-2009, 11:20 AM
  #45
TURBHOE's Avatar
well, you just suck it was 70 here then next day 11"s of snow
Old 03-07-2009, 08:22 PM
  #46
TURBHOE's Avatar
i need the arp pro series stud torque specs. what the arp torque specs and what does every body torque them to?
Old 03-07-2009, 08:37 PM
  #47
MikeGyver's Avatar
This is from the installation instructions for AFR heads: "Head Bolt Torque:
Apply moly-oil mixture to washers, and area around head bolt to prevent galling and improper torque readings. 11MM ARP torque to 70 ft. lbs. with moly lube, 8mm torque to 23 ft. lbs. with moly lube. A re-torque is recommended after initial start-up and cool down (allow 2-3 hours for cooling). Sealer should be applied to all head bolts or studs that enter into the blocks water-jacketing system. Permatex is a good general-purpose sealer."
Old 03-08-2009, 07:20 PM
  #48
TURBHOE's Avatar
torqued them all 5 times. just like the web site says. man was that a pain.
well, new lifters are in, heads are on, push rods in, rocker arms torqued, and valve covers installed. i applied orange rtv to the intake rocker arm bolts, since the intake runners were opened up.
the battery logo on the heads thing, what all models and years does that cover?
Old 03-09-2009, 12:35 PM
  #49
white lightning SS's Avatar
01-05 Engine vin's V,T,M,B, and Z
Old 03-09-2009, 12:46 PM
  #50
TURBHOE's Avatar
so ls6 heads?? also are they garrenteed to leak or it might happen? i just installed a set of port and polished ls6 heads and i'm gonna be pissed if they do.!!!
Quick Reply: took off head got pics.
