Torque sequence for oil pan?
I know the small bolts go 18# starting from the center. What about the two long bolts? I broke one trying to tq it to 18#. Also what about the 2 bolts thru the tranny case? Do they go in first or last and how many #s? Thanks for the help fellas.
i start from middl out doing 18#s. out side ones i go hand torque.. if you have good feeling in your hands youll feel when its just about right. also becareful with front 2 also since you can strip out or break the inside of the front cover and thigns can get caugh up in the pick up tube...i found this out the hard way.
Alvin@PCMofNC
09-03-2015 06:38 AM
