TR224 112lsa cam
#21
there definately is a 1500 lq9 6.0
they make the ss in a 2wd platform
i thinki remember reading that exhaust biased cams with a higher lsa (114) are better for spray, but im no cam guru. just read alot... read up. theres several great cam threads that will explain more than youll ever need to know.
#23
yea, i'm going to call around this weekend and figure out which trim levels you can get it in too.
as far as the stall goes, if I can pick up a decent stall that's used, would it be worth it? or should I just buy a brand new one?
#25
received... sounds good.
here's another question for yall...
what're the best springs for maybe the 220 or 234, I'm thinking about getting the 918's from crane. are the comp springs better? thanks for the info
