Trick flow cams
Old 02-23-2012, 05:56 PM
redsilv's Avatar
Default Trick flow cams
I have done research on these cams from trick flow.
I have been looking all over the damn internet to find videos or even reviews
Anybody running one of these?
I am looking to install the trickflow 216/220 in a lq9
then having my 706 heads worked by AI for next winter
cam specs:216/220@.050 .560/.560 114
Im hoping that the 6.0 will have midrange power but still some low end torque
Its not the compcam 216/220
Anybody?
Old 02-23-2012, 06:07 PM
MASS seller approved
Petey62782's Avatar
If u want to take the geuss work out of picking a cam contact Pat G from guerra motorsports and for $25 he will spec u a cam tailored to exactly what ur looking for he will even point u in the right direction for the springs to match the cam. He really really knows cams so much so that he can have a successful business by doing it. I too have a lq9 and he speced a cam for me and I was very happy with the info I learned from him and the specs he gave
Old 02-23-2012, 06:17 PM
redsilv's Avatar
im not looking for a spec cam just looking for any one running a trickflow cam
Has anyone ran a trickflow cam in a 6.0?
Ive seen the 5.3 trickflow head/cam setup in the dyno section
Old 02-26-2012, 06:37 PM
redsilv's Avatar
ttt
nobody run these cams?
im expecting awesome midrange power
the 317 heads will be milled and im going to use a thinner
gasket to help my quench
im not looking for the 1/4 mile with it
but if im going 65mph i sure hope to pass somebody
any input would be great
to hear about
Old 02-26-2012, 09:17 PM
jrmchevyman's Avatar
The trickflow 216/220 should be similar to the comp 216/220 I am assuming, but the trickflow one has more lift. IDK what kind of lobes trickflow uses.
You are correct that cam will be more of a torque cam since you are putting it in a 6.0.
Old 02-26-2012, 09:28 PM
Swerve7rpm2000's Avatar
im pretty sure comp produces the cams for trickflow, they just reserve the right to put the brand name on it when they spec it...
Old 02-27-2012, 04:47 AM
redsilv's Avatar
i appreciate the feedback guys
i too think i heard its a comp grind
i cant find anywhere what lobes trick flow uses
i wanted a cam with not too much lift (spring life)
this truck sees alot of the 2-5k rpm being on the highway
and the steep inclines
what tranny cooler are you guys running?
i know that my 4l60e wont last long
especially when i get that 278mm stall from chris at circle d
Old 02-27-2012, 11:05 AM
Most people get the tru cool 40K cooler. The 278mm is a pretty tame converter vs the smaller diameter converters.
Old 02-27-2012, 11:27 AM
charcoal03silvy's Avatar
i don't have a cooler on mine, and haven't had any problem with the trans temps getting too hot. i have the 278mm from circle D
Old 02-27-2012, 05:39 PM
redsilv's Avatar
im sure that chris will recomend somewhere around a 3k stall
so i am just trying to save every bit of the 4l60e i can
the trucool sounds pretty good but its a little more expensive
than what summit offers?
Anything bad with the summit coolers?
I figured i would give the transmission a fighting chance- lol
I do sometimes stay in the 3500-4000 rpm range for awhile
thanks for you guys input
Quick Reply: Trick flow cams
