TSP 220r cam and California emissions?
IMO, that will pass with a decent tune. You can also run some denatured alcohol in the tank to cut down on the emissions.
In 2013, CA is doing away with the sniffer part of the smog test for 00+ cars. They will only have the visual and functional (OBDII) tests. In theory, you can use as big of a cam as you want. I'm not sure what they can do if it sounds or smells cammed. No one is really sure yet. They might tighten up on the functional test as in no more tuned PCM's. Who knows...
SmogTips.com - AB 2289 - Smog Check Law California. No more tailpipe smog test. Elimination of tailpipe smog check testing for 2000 model vehicles and newer.
I can't see how adding more ethanol to "lean it out" btu wise will help that much with HC emissions when a cam is allowing to much blow through at Exh. close and Int. open. Might help a tad, but just make sure to get your mechanical side of things in order with a good tune. Find a place that has an exhaust gas analyzer and see if your tuner can come with you to run the tests and make adjustments if needed to get "in range."
Edit: After reading some more, it seems that do to lower btu content, the higher Alcohol content in the fuel will encourage a cooler combustion event which "should" lower NOX emissions.
All California pump gas that I have seen is E10 or 10% Ethanol (denatured alcohol) already, unless you find a station that sells straight gas.
Anyways, I did 3-4 gallons of gas to 1 gallon of alcohol and it worked fine. I just made sure to fill it up with gas right after the smog.
Corvette454l88
09-01-2016 01:24 AM
