Tsp 231/237 .598/.595...
Has anyone used one of these in a 6.0??? i am using 317 heads, that have been milled .020, arp rod bolts and basically stock from there, just curious if anyone has any input on this???? Just wondering if i should keep the TR224, or go a little bigger???
Thanks
Brian
Thanks
Brian
High on diesel fumes
If you decide to go with something that size I have a 235/239 .600/.580 113 +4 for sale here
https://www.performancetrucks.net/fo...d.php?t=393274
231/237 would be an awesome cam. But IMO you dont have enough converter. The 224/224 would be a nice cam in a 6.0 with a tt3000. You are going to need 4.10's and IMO atleast a loose 3400 to run that 231/237. Also another cam is the torquer v2 with the lsk lobe. Both of those would be awesome and I think the torquer v2 may give you a LITTLE bit more low end.
Originally Posted by ramdaspadhye
There's one by Comp Cams... XER281HR... 281/283 232/234 .595/.598 112lsa Not tryin to get away from the sponsors, but that looks like it'd be a nice...lopy cam
jtphelps289
09-29-2015 12:00 PM
